4030 diesel antifreeze in oil
DCman
06-14-2004 14:14:51
I have a 4030 diesel that is getting a small amount of antifreeze in the eng oil. Anyone know of one specific place to start looking for the problem? Tractor only has 4300 hrs on it. Also has a miss in it, sounds like an injector to me. Thanks for any help.
Indydirtfarmer
06-15-2004 08:43:51
 Re: 4030 diesel antifreeze in oil in reply to DCman, 06-14-2004 14:14:51
If you're getting moisture blowing from the crankcase vent tube, then you might be having the "electraulisys" problem Tim(V) is talking about. In order to confirm that's the problem, pull the oil pan first. Then pressurize the cooling system. (About 15 psi will do the trick) You should see anti-freeze, or air bubbles coming from the bottom, inside of one or more of the cylinder sleeves. If so, they are toast. they'll get holes, that look like someone took a cutting torch, and blew holes in them. Cavatation, and rust particles are to blame. (Along with improper Ph levels in the coolant) In addition to the coolant treatments, Deere offers a filter system for the 4000 series tractors. It has a removable filter, much like an oil filter, to clean the coolant. Deere engines from the late 70's, through the early 90's are particularly suseptable to the "problem". I know. Your local Deere dealer should have info on the issue. John
Russ
06-15-2004 17:08:16
 Re: Re: 4030 diesel antifreeze in oil in reply to Indydirtfarmer, 06-15-2004 08:43:51
INDY..MER's RITE; YOU SHOULD BE ABLE TO GET A TECH BULLETIN INTERNAL REPORT THAT DESCRIBES THE LONG TERM PROBLEMS OF UNSATISFACTORY COOLANT PH.
THE CAVITATION, ELECTROLYSIS AND BAD COOLANT CHEMISTRY HAVE TAKEN DOWN MORE THAN ONE PROUD DEERE AND ITS MASTERS WALLET. GOOD LUCK IN YOUR EXPLORATION AND REPAIR EFFORTS.
Indydirtfarmer
06-15-2004 08:45:05
'scuse me! Tim(NJ). John
Tim(nj)
06-14-2004 18:08:23
Only 4300 hours. That's about right for the 329/359 engines to fail. Check oil cooler first. Is there a small amount of liquid dripping out of the ventilator tube? If there is, I bet you've got a cavitated sleeve. If you overhaul the engine, from then on make sure to do a regular coolant check for pH and use the coolant conditioners for wet sleeve engines. They are fussy.
R. John Johnson
06-14-2004 15:56:02
Have you run the engine with anti-freeze in the oil? If so, you will need to inspect main and crank bearings. Two falls ago I ran one of our JD 510's (the Manaheim built 3 cylinder) for half an hour with anti-freeeze in the oil. I was going to change oil before storing for the winter. When I dumped the oil it was milky. That short time ruined the bearings, but had not damaged the crank. The cause of the leak was a pitted sleeve that allowed anti-freeze to leak past the O-ring.
Good luck in your problem.
R. John Johnson
06-14-2004 15:55:41
Bob
06-14-2004 14:58:56
Pitted sleeve, bad head gasket, warped head, cracked head, broken head bolt, bad oil cooler.
Steve
06-14-2004 19:04:10
 Re: Re: 4030 diesel antifreeze in oil in reply to Bob, 06-14-2004 14:58:56
JD also had a problem with the ring around the top of the sleeve cracking
