1010W Pwr Steering Woes
Robert
06-14-2004 11:59:22
I have a 1010W s/n55512, loader/backhoe tractor. It has pwr steering of the type with hyd assist cyls attached to the drag link. I have no power assist. I removed the torsion valve (in-line behind radiator), and it seems to function ok. no leaks, and directs fluid properly when twisted. I have not yet removed the prw steering pump (behind dash) Yes this is the pwr steering ONLY pump, as the main pump for loader & hoe is front engine mounted. However, the reservoir is filled with automotive pwr steering fluid. Does anyone know what JD says to use? I'd try replacing the oil first before yanking the pump. Has anyone rebuilt that pump? Are parts available?
Thanks in advance
Robert
