4020 Carb Problems(Zenith)#AR45162
L Bryan
06-13-2004 19:55:37
Carb will not adj with idle screw when throttle screw is out so plates are closed. Does eletric solnoid on bottom of bowl do any thing but shut off fuel when motor is stopped? Carb has been cleaned, new accelerator pump& check valve. I&T shop book tells very little!!! Any advice would help.. thanks LB
