New-Gen
06-13-2004 16:18:54
Actually the problem has already been solved, I just wanted to share it with you in the hope that maybe it might help sonbody else solve a problem. The governor started acting up-pulled tractor in shop, pulled pump off, took it to rebuild shop--the went clear through it-good as new-- Brought pump home, went to put it on--wouldn't go on. Before I take a pump off, I always line up the flywheel and pump timing marks--looked closer-somebody had installed the oil pump 180 off. No problem, just pull the shaft out of the pump, put it back in 180 off, bolt pump on, hook everything up---and---won't start!! Had fuel to injectors-called shop, they said bring it back in, we'll check it out. So, off comes the pump, back to the shop, this time with the injectors too. Pump checked out right on specs on teststand, injectors all weak but not bad enough to keep tractor from starting. Back home, put it all back together, bled it out, STILL WON'T START!!!! Out of sheer desperation and lack of anything else to try, pulled pump AGAIN (by this time I was getting pretty good at it}, pulled shaft out, put it back in the correct way, (remember, the oil pump is in backwards, so now the timing mark is around back where it can't be seen},guessed at the static timing, buttoned everything back up, hit the starter, and IT STARTED!!!!! Turned pump to the position where it ran the best, (I know that's not right but till I get time to fix it right it'll have to do} Called the shop, put our heads together, came to the conclusion that whoever put the oil pump in wrong went to the trouble of taking the injection pump apart and turning the weight retainer 180, so it could be installed with the shaft in correctly. Kinda like 2 wrongs trying to make a right--and when my guys disassembled the pump, they had no reason to look pay any attention to the weight retainer, they just installed it correctly when they reassembled the pump. Anyway, the tractor is running now, and hopefully this will save somebody some aggrevation next time they have to follow a shadetree mechanic into an engine! Another good arguement for service manuals!!
