Deere 2010 and 613 mower
JD Convert
06-13-2004 14:11:22
Looking at at 2010 utility tractor-gas. Currently has front end loader on it and runs well. Everything sound with no drips.
Currently have a JD 613 mower that I inherited. Cannot find if it is compatible with the 2010. 613 says it needs a category 1, 540 PTO. Says it needs a Tractor PTO HP of 22HP. Can anyone tell me if the two will work together?
T213R
06-13-2004 16:18:52
 Re: Deere 2010 and 613 mower in reply to JD Convert, 06-13-2004 14:11:22
Yes, the 3ph on a 2010 will work. You have 45hp as well! If the 3ph (I don't have a good picture or I'd know) has sway blocks, they should be set for cat 1, and you will likely need the sleeve adapters.
