1010 Valve Bank
Craig Ruschkows
06-13-2004 10:15:56
Hi, I have a 1964 1010 Crawler with a cessna Valve bank. After I plumbed in a backhoe the main valve bank blew-out the end cap (a hole as big as a quater). I was wondering if anyone can help me locate this this end cap the casting # which is located on the inner part of the casting is 30100-108C or 30100-1080 (hard to tell what the last # is for sure. Also I'm not sure what caused it to blow-out one person mentioned a Power-beyond valve should be used between the main valve bank and the hoe's valve bank (I'm not even sure what this is). Everything was working fine for a couple of days with out one. Cessna no longer makes this part so if anyone has any information that may help me locate this end cap it would be much appreicated. Thanks. Craig R
Tony Miller
06-15-2004 19:53:51
 Re: 1010 Valve Bank in reply to Craig Ruschkowski, 06-13-2004 10:15:56
Sorry, I mispoke a little. Instead of reinstalling the large plug in the loader valve bank end cap, that is where you hook the line to run the hoe valve bank. Then from the hoe valve bank return, you "T" into the original return line from the loader valves. Just be sure to put quick disconnects in the lines to the hoe, as you'll find you will want to remove it to do much loader work, as it makes the unit to back heavy. Just make sure the engine is off when you disconnect the lines, or it will dead-head the hydraulics. Then arrange the disconnects so you can connect the lines on the dozer back to one another. If you give me a fax number, I can fax you a papge from the 50/51 backhoe manual showing the correct hookup, and a parts breakdown of the loader valves.
Billy Raley
07-02-2005 22:02:11
 Re: Re: 1010 Valve Bank in reply to Tony Miller, 06-15-2004 19:53:51
Tony:
Could I get a copy of the 50/51 backhoe manual since I don't know what I have, it's a (John Deere
1010 backhoe) Send me a e-mail & I'll give you Fax Number. Thank's
Craig
06-16-2004 19:04:20
Tony thanks for helping out. You are the first person I've heard this from and it makes total sense. I've tried to weld it twice first time with stick and had cracking and porosity even with pre-heat, peaning and post-heat. decided I'd try to braze it but didn't want to stick and had porosity in my brazing even though I thought i'd burt all the oil out. someone said try boiling it, mabey I'll wash with solovent than try the boiling thing. I will have to pull the valve apart again to see if I can find the tapped hole and go from there, sounds like you have something similar as my end cap has a plug in it also, 3/4 NPT I belive. I have a fax machine but rarley use it (i just kinda plug it in if I know someone is going to fax me) but if you could mabey e-mail me your phone # i could call you one evening when your not busy and set it up. Thanks again I think you saved my day. [email protected]
PS i'm on PST in British Columbia
Tony Miller
06-15-2004 19:40:48
Well, I may be able to help some. I added a hoe to my '65 1010 crawler. I do not remember which valve bank I have, but, to convert to power beyond, you simply removed a large plug from the valve bank, and screwed a smaller plug into a pre-tapped hole inside the housing, and reinstalled the outer plug. Voila, power beyond. What that means is that you can actuate a second open center valve bank (the backhoe) from the same pump buy piping in series with the return line from the loader valve bank. That plug will seperate the tank return from the loader valve bank and the open center bypass flow going through the valves, so that you can send the bypass oil to the hoe, while still having a tank drain (to reservoir) for the loader cylinders. Sounds like you tried simply connecting the hoe in series, without that internal plug to seperate the flows, and may have built up excessive pressure in the loader valve housing in an area that wasn't designed to withstand it. Hopefully you can repair the cap that popped out. You may be able to locate a new valve end cap. If you look into the hole where the cap (plug) popped out, and see a pipe threaded hole, then your in the right spot.
