Auction results, Durand WI
Kent W
06-13-2004 06:14:13
$16,000 1964 RARE John Deere 3020 Diesel High Crop, been through the shop! Great tractor, 3 point, numerous new parts, sn. 60666
$ 7,500 1961 RARE 4010 Diesel w/ Levy Live Power Front Wheel Assist, 3 point, weights, really an impressive tractor, sn. 1770
$ 9,500 1982 John Deere German 4240 Front Wheel Assist, made for the export market, several differences, single remote, 3 point, sn. 31242
$ 9,000 1978 4640 Front Wheel Assist, Quad range, 2,4XX hours, uses this tractor regularly, sn. 004557
$39,000 1920 Waterloo Boy Model N, has been mechanically gone through, very nice original tractor, has adjustable plow hitch, sn. 26710
$11,500 1930 GP Wide Tread, repainted on full steel with correct 44" wheels! sn. 401709
$13,500 1938 G, Low Radiator, repainted, on full steel sn. 1987
$ 4,500 1934 A Open Fan Shaft, repainted on full steel sn. 411792
$ 3,750 1936 AR repainted on full steel with brass tag sn. 251185
$ 6,500 1930 GP repainted on full steel sn. 223386
$ 5,250 1938 G High Radiator, repainted on full steel sn. 6633
$ 5,000 1935 B brass tag, factory rear spokes, single front sn. 5747
$ 3,750 1938 B cast rears, single front sn. 47644
$ 2,100 1940 A single front sn. 489754
$ 2,400 1939 B single front, flat spokes sn. 63808
$ 2,750 1937 A repainted on full steel sn. 450601
$ 2,750 1937 B repainted on full steel sn. 33957
$ 2,300 1937 B repainted on full skeleton steel sn. 29003
$ 3,750 1936 B repainted on full steel sn. 21004
$ 2,750 1928 D repainted on full steel with rear extensions sn. 62391
$ 5,250 1938 G, correct sn. for low radiator, but has high, unerestored, sn. 1539
$ 4,200 1938 BR repainted on full steel with extensions sn. 328461
$ 3,500 1935 B repainted on full skeleton steel with brass tag sn. 7523
$ 2,750 1937 A repainted on full steel sn. 450606
$ 4,500 LA repainted, weights and cultivator
$ 3,500 1937 B repainted on full steel sn. 45919
$ 2.100 1938 B on rubber, cut offs sn. 47330
$ 2,750 1953 40 repainted, single front wheel, 3 point sn. 63892
$ 3,750 1947 MI repainted, 3 point sn. 10849
$ 6,000 1939 G repainted, full steel, 2nd model for 1939 sn. 7735
$ 2,000 1951 MT all original with cultivator sn. 32066
$ 2,500 1939 A, 36� round spokes, fenders, original, sn. 483080
$ 4,250 1935 B, 4 Bolt, original front steel, STUCK, sn.2518
$ 2,100 1938 B on cut-offs, sn.47330
Auction comments, not impressed with Kurt Aummann as an auctioneer. Auction should have split up into 2 rings with one selling Oliver tractors/parts and the other selling John Deere tractors/parts. Kurt also in my opinion does not do a good job of managing his time during the auction, spent more time trying to get 5 dollars out a part than 100 dollars out of a tractor. Been to his auctions before where the sane thing has happened and probably would not go to another of his auctions even if there was a tractor that I wanted.
Was There Too
06-13-2004 14:33:18
 Re: Auction results, Durand WI in reply to Kent W, 06-13-2004 06:14:13
You haven't been to too many auctions if your not impressed with Aumann's - the best in the business as far as I'm concerned. I was interested in both John Deere's & Olivers - I would have hated it if they split the auction like that. To each his own I guess.
Duane Larson
06-15-2004 11:05:21
 Re: Re: Auction results, Durand WI in reply to Was There Too, 06-13-2004 14:33:18
Just got back home - I agree fully with you. I bid on two Olivers and bought a JD. I have gone to Kurt's auctions for 10 years and think he is one of the best. Straight as an arrow - no odd bidding, etc.
Mark
06-13-2004 08:54:55
Wow, good price on the 4640, I'd have bought it..
KS in OK
06-13-2004 07:29:06
Many thanks for the results. I really appreciate it. I could'nt quite justify the drive from Oklahoma for an auction, and it looks like they sold well, Thanks again, K.S.
TPat
06-13-2004 06:52:57
Thank you for the information on the auction!!
