3020 weep hopes
mikeinWA
06-12-2004 23:44:46
Starting to notice a thin film of oil from weep holes. Only use the 3020 in spring and fall for plowing and disking. Any ideas on how long I have before a rebuild, or anything to watch for to save me from any real ($$$) damage? I am not real familiar with this machine any info on the cause and repair would be helpful. thanks
JimKS
06-14-2004 18:18:40
 Re: 3020 weep hopes in reply to mikeinWA, 06-12-2004 23:44:46
this might be a dumb question... but what are these weep holes in?
mikeinWA
06-14-2004 23:09:02
 Re: Re: 3020 weep hopes in reply to JimKS, 06-14-2004 18:18:40
They are located on the left side of the block below the manifold. They are about the size of a BB in diameter.
cole in mo.
06-13-2004 05:35:54
The cause is the liner O rings are letting go. If its just oil you will be ok for a while, but if you see antifreeze leaking out the weep holes, be carfull, the next place it will go is in your oil.
Chris
06-13-2004 19:32:10
 Re: Re: 3020 weep hopes in reply to cole in mo., 06-13-2004 05:35:54
I have seen some people put 3 o-rings in. One for coolant, one for oil, and one to cover the weep hole. Those o-rings are made from different material and oil could hurt the coolant one if the weep holes get plugged. Just watch your oil.
txblu
06-15-2004 09:37:41
 Re: Re: Re: 3020 weep hopes in reply to Chris, 06-13-2004 19:32:10
Had to do an inframe just because the weep hole was leaking. As it turned out, previous owner had redone the seals but put the wrong one in the right place. Both came out swollen and decomposed from being in contact with the opposite fluid for which it was designed.
Mark
mikeinWA
06-13-2004 20:37:56
Thanks fellas.
