2010 JD Roosa Master fuel pump(no fuel at injector
Mike Rose
06-12-2004 19:41:17
I have a 2010 JD ssn# 69183 the tractor was a backhoe at one time. Well I've be trying to get her running. It would run, but badly white smoke, hard starting, no power. The tractor was supposed to be all rebuilt new pistons liner head, but was out of time. Well that another story$%#@#@$$$$$$$$$%%^@$$
I tore the motor down I new I was getting psi. in the coolant, head, head gasket repaired pistons were broke between the comp. rings new pistons and rings; liners and plat where pited but within tolerance
Well the shaft come out of the fuel pump when I tore the motor down. I lined up the line in the pump with # 1 cyl. dot to dot; to the oil pump. oil pump slot pionting at # 4. NO FUEL at the injectors I have fuel at the timing window, at the returns, filter but not at the injector lines? Help with inf. out of $$$$$$$$$$$$$$
Wife Needs to hear Run..
Mike Rose
06-14-2004 18:25:09
 Re: 2010 JD Roosa Master fuel pump(no fuel at inje in reply to Mike Rose, 06-12-2004 19:41:17
Yes I did take the shaft out I have done everything how you said but oil pump dot is pointing at #4 per JD manual. Have worked as a mechanic all my life But I have never took a fuel pump apart.Thanks Mike Help with the pump
DON
06-13-2004 08:12:02
MAKE SURE YOU HAVE ENGINE ON NO.1 TDC, LINE UP THE TIMING MARKS WITH THE WINDOW. DID YOU HAVE THE OIL PUMP OUT? IT HAS TO BE TIMED WITH SLOT RUNNING PARLELLE WITH THE BLOCK. MAKE SURE THE PUMP SHAFT IS IN THE INJ. PUMP CORRECTLY. THE SHAFT IS OFF SET. ARE THE PUMP SHAFT SEALS IN PLACE CORRECTLY ONE FACEING DOWN AND THE TOP ONE FACEING UP. NOW THIS PUMP IS A SPEED ADVANCE SO YOU NEED TO ADJUST THE TRIMMER SCREW WITH THE ENGINE UNDER LOAD AND WITH A TIMING WINDOW. DON
Bob
06-13-2004 09:05:43
 Re: Re: 2010 JD Roosa Master fuel pump(no fuel at in reply to DON, 06-13-2004 08:12:02
DON,
He says he's not getting any fuel to the injector lines. He needs to find out what's wrong with the pump, and timing is NOT the reason it's not delivering fuel!
