Engine parts back from Machine Shop.
Help Needed.
06-12-2004 13:30:55
1944 John Deere Model B the crank shaft mains are standard and I am putting new bearings from John Deere back in. The rod bearings are 2.738 which is 10 thousands less than standard.
1. Do I need to have my rods rebabbitted or can I just take out a few shims? There are no big pits and looks fairly smooth.
Greg S
06-13-2004 07:58:38
 Re: Engine parts back from Machine Shop. in reply to Help Needed., 06-12-2004 13:30:55
Unless there is some minimum diameter that I am not aware of, I would probably just check the journals for obvious signs of deterioration. Then I would measure for out of roundness and look for any sort of taper. If everything was round, then put the connecting rod on the crank journal, and remove an equal number of shims from the top and the bottom of the connecting rod until some drag is felt while turning the crankshaft. Then, add one .003" shim to the top and one .003" shim to the bottom of the connecting rod. This is for proper oil clearance.
