3020 running rich
Robert Barcus
06-10-2004 18:40:37
I just bought a 1964 3020 to use with a 709 rotary mower. I notice that the tractor is running rich. A slight miss and a little black smoke from the stack.
How can I adjust the carb to lean it down a bit?
Robert
Russ
06-13-2004 20:41:06
 Re: 3020 running rich in reply to Robert Barcus, 06-10-2004 18:40:37
Robert, There were two types of gas carbs for that model. The Marvel-Schebler has the float bowl on the side at an angle (flat cover). The Zenith uses the bottom of the carb as the float bowl (traditional style).In either case, you're going to be adjusting the high speed (load mixture) and then the low speed (idle mixture).
M.S. carb: The low speed screw is located on the top just under the mounting flange hole.
The high speed screw is located at the lower edge of the side away from the engine.(it's staring right at you.)
HIGH SPEED SCREW= 2-1/4 TURNS
Zenith carb: The low speed screw is located in the same position as noted above. The high speed screw is located on the lower right side of the fuel bowl(It should be a "T-screw").
HIGH SPEED SCREW= 1-1/2 TURNS
1) Turn the high speed screw in until lightly seated, then back out the # of turns listed. Get engine to temperature and set throttle to wide open. As you turn the screw in (lean), the RPMs will raise and the engine will run really smooth. Turn the screw out (richer) until the engine just starts a slight rich sound. This is the optimum power setting under load. (Since you're not familiar with the sound, just experiment a little by turning the screw out more and you will then notice the rich exhaust and rich sputtering/missing.Better to be a LITTLE rich than lean.)
2) Return the throttle to idle (420 RPM) and adjust the low speed screw to obtain the highest idle.
GOOD LUCK!
Robert Barcus
06-16-2004 13:10:57
 Re: Re: 3020 running rich in reply to Russ, 06-13-2004 20:41:06
Thanks!!! I will give that a try Friday. I have found several other things that have contributed to the 3020 running not as good as it should.
