Gordo, once that set screw is removed just reach down with a screwdriver & kind of pry/rotate between the eccentric notches & the side of the gear housing with the screwdriver & the eccentric bushing will turn.. It helps a lot to lightly jack the front end until most of the weight is off the front tires, that takes most of the side load off the bushing & allows it turn easier.. ~Try turning that eccentric bushing both directions, you could easily turn it the wrong way to begin with.. If you turn it a long ways & still can�t get a decent adjustment suspect the bushing off-center hole has worn enough to now be in the center of the bushing [worn egg shaped] & not moving the sector gear closer to the worm [a somewhat common problem on a well used tractor].. If that bushing is worn you can try Deere but some bushings aren�t available anymore.. Either a good used bushing or boring yours out & installing a new off center thin walled bushing will then be required.. ~You might first want to try pushing & pulling on the steering wheel & if any fore/aft end play is felt in the horizontal steering shaft you should adjust the worm bearings first.. ~While you have the front jacked up just jack it up a little farther until the front wheels are slightly off the ground then use a long bar & pry up on the front vertical steering shaft [between the wheels] if you have a measurable up & down movement you might want to pull the pull the worm gear & add a thin washer or two between the bottom of the worm gear & top of the bushing.. ~Obviously loose front wheel bearings or worn Roll-o-Matic arm bushings should also be adjusted or replaced.. ~If you get to the point that adjusting that eccentric bushing makes the steering bind on center but feel good off center then you should try removing the sector gear & rotating it 180� as that will then allow the worm gear to mesh with the unworn part of the sector gear [will just like installing a new sector gear .. Any questions on the above just post back or E-Mail� [email protected]
