Hubs on cast wheel centers
Kevin
06-10-2004 12:30:35
I want to adjust the spacing of the cast center of the rear wheels on a JD 4010. The half sleeves and rack & pinion have not been moved on the axle for 43 years since it was built. How much of a job is it to get these to move without destroying something? Any info would be greatly appreciated. Thanks!
Kevin
06-11-2004 06:17:15
 Re: Hubs on cast wheel centers in reply to Kevin, 06-10-2004 12:30:35
Thank you all for the information.
Heat Houser
06-10-2004 17:21:03
My 4010 centers hadn't been moved in years. I went to 30 inch rows so had to slide them in. I loosened the bolts on the inner and outer wedges, drove around, clutched and popped the brake on the side I was working on. You will hear a pop when the wedges come loose. Works great and doesn't burn up your yellow paint.
Jason Z in MO
06-10-2004 14:39:09
I have been through that battle with my 4020! I assume you have a manual that will explain the whole process. I will give you some things I have learned. Sounds like GMAN has the real experience, my comments are from what I learned on my 4230 and the real problem child 4020.
First thing I would do is soak the bolts and axles with your favorite penetrating oil. It probably won't do much good but it will make you feel better that you did it! You can never say it didn't help!
The big problem I had was broken bolts. The jack bolts have a long shank after the years of exposure the shanks had weakened with rust and broke off where the threads enter the cast hub threads. When I do it again I would use more heat ON THE BOLTS. Use a good soaking heat till red hot and let them cool. You might have to heat them a couple of times to get them to loosen without breaking. When you put the wrench to them be sure to feel for the threads to turn and not the twisting of the shank. If they won't move, leave them go, the wheels can be freed without them. Once the wheel is free you can access the back of the bolts to apply penetrating oil and direct heat to the threads.
I didn't have too many problems getting the three 7/8" bolts loose. These 3 pull the wedge into the hub and clamp it to the axle. The two jack bolts I talk about above are used to press the wedge out of the hub. These two bolts can not be removed because they have a retaining clip on the back side. If you try force these out you will damage the bolts, retainers, and possibly the threads. Regardless, they will bind and you won't get them out without breaking them. Once you have everything loose you can remove the wedge to remove the retainers.
If you can loosen the three 7/8" bolts (I am referring to 4020 sizes, assume the 4010 was the same) and the jack bolts are frozen. I have heard of people carefully driving around to loosen the wedges. I would have tried this but my tractor was in various pieces when I had to remove the wheels.
I beat, heated, fought and cussed trying to free those %^&* wedges but couldn't get them to budge. So I broke down and hired our local traveling JD mechanic who assured me he could get them loose. Sure enough for $50 bucks he had them free! So for $25 I will tell you the secret...
Just kidding... What he did was loosen the 3 inner bolts pulling the other half of the wedge to the hub. (Normally these don't need to be touched.) He drove the pinion gear drive pin/bolt out. There is a plug in the hole opposite from the wheel adjusting bolt. This simply drives out of the pinion gear. With the tractor securely blocked up (By now it should be blocked safely with the rack on the axle at the 12 o'clock position.) With an 8 pound sledge he hit the end of the axle!!!! These were not light swings either! Before he did this he told me most people get nervous or upset at what he is about to do. This is how he was taught at the John Deere classes. After a couple of good licks things started to move! After the wheel was off I removed the final drives, these axles and housings can take the abuse! I told my Grandpa about how the wheels were freed and he shrugged and said, "sure, just like how you put an axle head on a handle, you don't hit the head but the end of the handle...".
The only problem I had left was the broken bolts down inside the casting. After several attempts at drilling, heating, soaking, bolt extractors, and more cussing I remembered something. I had heard the steel bolts will melt at a lower temperature than cast. Since I already had drilled holes through, I took my cutting torch and melted the bolts out. What a great feeling to see the bolt threads melt away like butter with the cast threads keeping their shape. After cleaning the threads with a tap the new bolts worked just fine! (The wheel will need to be laying down on the ground so the debris will fall away.)
Do everything you can to avoid the broken bolts. To melt them out you still need to drill a good size hole through them and they are down inside the casting.
This is mostly rambling but I hope it helps you get your wheels free.
You can email me if something doesn't make sense; [email protected]
G-MAN
06-10-2004 13:44:56
If the tractor has been kept clean and out of corrosive substances like manure, they might not be too bad. If it's been in lots of cow or hog lots, you might have a fight on your hands. On a tough one, I start by backing the wedge bolts off slightly and driving the tractor around, alternately turning hard and hitting the brakes pretty firmly to get things moving. After that, it's a matter of patience, penetrating oil and maybe some heat. I'd soak them with good penetrating oil for several days prior to starting. And don't think that the forcing screws will always free a stuck wedge, as you can easily break a wedge or break off the screw if you get too frisky with them. One of the best methods is to make a tube that will fit over the axle, and that has a cut-out area that will fit against the wedge, and then beat on that part of the wedge with it. Then you're putting force on the part of the wedge that is in contact with the axle, not the flange area that the bolts go through. You can also beat on the axle end to some degree, if you make sure not to damage the snap-ring groove or mushroom it badly. Some guys say not to, but I've seen a lot of beat-on axles that ran a long time with no final-drive issues. Patience is the key, and you might have to heat the hub around the wedges some. This is one of those jobs that you just get a feel for after doing a dozen or so. You start to figure out what works and where to concentrate your efforts, instead of beating on everything you can get to. And when going back together, chase out all bolt holes, remove the pinion shaft and gear, and give everything a good coat of anti-sieze.
