730 Power Steering
bent
06-10-2004 08:24:19
Ok, I received my manuals. One of the things is says to do is scribe the valve housing and the worm housing prior to disassembly. Where do you scribe (ie. top, side ??) and why? Is there that much variance in how the valve housing can be tightened to the worm housing?
Thanks as always in advance
Brent
Clooney
06-10-2004 09:07:06
 Re: 730 Power Steering in reply to bent, 06-10-2004 08:24:19
Bent, you scribe between the top of the valve housing right on over to the worm housing.. That setting is real critical as about .002" is enough to make the wheels turn to one side by themselves & probably .010" would make them slam over to one lock or the other as fast as possible..
~I personally usually don�t go to the trouble of scribing those housings as any measurable work inside will make those lines somewhat useless anyhow & then after it's adjusted correctly I scribe a re-match mark between the housings. If too many scribe lines are used there will be lines all over the housings..
~I just bolt the valve housing on & center it by eye then if the steering starts to turn on it�s own while cranking I move the valve housing slightly until it at least stays put while cranking..
~If this is your first steering work you probably should mark [scribe] the housings then make darn MAKE SURE you don't stand with your legs between the tractor frame & R/H front wheel [wide front tractor] while adjusting that steering valve centering..
Any other questions just post back or E-Mail..
[email protected]
F-I-T
06-10-2004 09:00:21
Brent:
Just scribe on either the top or bottom, and either the front or back. Use a nice sharp point, and yes, the alignment is pretty precise. When you reinstall it, you'll want to be close to your original position...it saves you time. When you do the fine tuning by tapping the actuator housing fore and aft, you'll be surprised how much difference .010" or .015" will make.
Frank
