336 Baler and #30 thrower
Dave Sherburne,
06-10-2004 08:21:38
Was baling first hay of the year, thrower worked fine for two loads. Just into the third load the #30 hydraulic kicker would barely throw them to the wagon, ANY IDEAS WOULD BE APPRECIATED.
Terry
07-25-2004 19:57:44
 Re: 336 Baler and #30 thrower in reply to Dave Sherburne, NY, 06-10-2004 08:21:38
Dave, i just got the same problem today on my 336. Wondering what you found out was the problem? I drained the oil and checked. Let me know I'm interested to find out if your baler had the same problem my is now having. Thanks!
Rodney A Johnson
06-11-2004 06:27:00
I assume you have found no obvious hydraulic oil leaks and that the hydraulic resevoir for the #30 kicker is full.
That is the only immediate possibility that comes to mind.
I suppose it could be possible to have a plugged filter and the pump cannot build up pressure (starved of oil).
When I was working on mine, JD dealer warned me to be very careful when draining the oil, and do not grab the filter hard, as there were many sharp metal filings typically in the filter and oil...they weren't kidding.
I think it took me about 7 gallons of hydraulic fluid to replace what was in the resevoir (put in a little extra, as I bale on very steep hills and wanted to make sure the pump would always be able to get oil no matter what angle the baler was at).
