2020 gitting hyd fluid in crankcase
Deere Heaven
10-22-2003 08:56:13
I have a JD 2020 that is gitting hyd. fluid in the engine crankcase is this possible? I am guessing its hyd. fluid because I have to add about 1 gallon every coupple of hours, and the crank case is filling up. There are no real bad leaks. What and where should I look for? Brian Nielsen Austin, Tx.
david val
10-22-2003 09:09:32
 Re: 2020 gitting hyd fluid in crankcase in reply to Deere Heaven , 10-22-2003 08:56:13
is there a steering pump on the timing cover?
that's the only place i can think of where hydraulic oil can enter the crankcase.
david
