3010 3 pt hitch
Ed
06-09-2004 19:59:16
While using my 3010 with loader to pick up storm damage limbs around farm I had the 6 ft bushog on the 3point. With tractor idling the mower would settle almost to the ground. How can I check where the leak is? As soon as I reved the engine up the mower would raise up and stay idle down mower slowly settle again thanks for any ideas! Ed
Russ
06-10-2004 18:04:29
 Re: 3010 3 pt hitch in reply to Ed, 06-09-2004 19:59:16
Ed,there are pressure and return valves located behind the triangular cover on the rockshaft control valve housing. The one in the upper position is the "return" and may be stuck in the open position (or not seating properly if you have a very, very slow drop). However, the o-ring and backup ring on the rockshaft piston itself may be bad. I'd check the return valve first though as it's a quick check. Just be sure the arms are down releasing all pressure. Use caution not to drop the springs or balls as you remove the cover.
Ed
06-11-2004 05:18:21
 Re: Re: 3010 3 pt hitch in reply to Russ, 06-10-2004 18:04:29
Thanks I will try that first. I have a jd repair manual I thought I would get some ideas here first. thanks again Ed
