JD 60 PTO CLUTCH
Keith
06-09-2004 19:45:38
Having problems with clutch slipping when using with auger or loader. Adjusted clutch per instructions in manual by tightening cam counterclock wise. Seemed to make it worse. Any ideas as to what should do would be appreciated. Thankyou
Clooney
06-10-2004 03:46:20
 Re: JD 60 PTO CLUTCH in reply to Keith, 06-09-2004 19:45:38
Keith, if the PTO clutch is adjusted per the manual & it still slips then you have internal clutch problems..
~The first thing to do is pull the PTO filler plug & sniff the oil.. If it smells like gear oil [you know the sulfurous smell] you have a leaking PTO pump seal & the entire rear of the tractor will have to come off to replace that seal [somewhat common problem]..
~If the oil smells ok then pull the PTO clutch pack out & look for worn disks, weak springs from excess heat, or warped disks from all that slipping..
~If your tractor has the early PTO clutch fork over-travel adjuster stop bolt on top of the PTO housing make sure that it isn�t hindering full clutch engagement..
~Usually when those PTO clutches are adjusted properly & still slip it�s either gear oil in the clutch or worn/warped plates..
[email protected]
