JD 2510 Diesel Power Shift (Rare?)
Dave
06-09-2004 19:24:31
Can anyone tell me how many 2510 PS tractors were built?
I'm looking at buying one and the owner is claiming that this is a very rare tractor.
It is a narrow front, row crop.
Thanks,
Dave
ET
06-10-2004 11:58:32
 Re: JD 2510 Diesel Power Shift (Rare?) in reply to Dave, 06-09-2004 19:24:31
When I was with JD we had a customer with a 2510 powershift diesil and it was underpowered for the powershift. The power consumed by the transmission was very noticable on a 52HP tractor. We ended up adding a turbocharger to the tractor and had it cranking 72HP on the dino.
mark
06-09-2004 20:03:47
There were not a whole lot of them built,somewhere around 1500 I think with the diesel.I'm sure someone will correct me if I'm wrong.There are 6 that I know of within 20 miles of me,5 diesels,1 gas,all still being used as working tractors mostly by the original owners. Most are used as chore tractors,have wide fronts with loaders.
Dave
06-09-2004 20:30:57
 Re: Re: JD 2510 Diesel Power Shift (Rare?) in reply to mark, 06-09-2004 20:03:47
Thanks,
The tractor is in good but not great cond. NF, single outlets, engine and trans. seem OK.
He says he'll take no less than $7500.00.
Deal or not?
Dave
Rodney A. Johnson
06-10-2004 06:56:35
 Re: Re: Re: JD 2510 Diesel Power Shift (Rare?) in reply to Dave, 06-09-2004 20:30:57
Last spring at auction here in south eastern MN, I saw a 2510 PS with dual hydraulics, fresh engine overhaul, new clutch, and starter, wide front go for about 7700USD.
Personally I thought that was high for a 52 HP tractor, but it did have some recent work on it. It was repainted, but the tin was fairly abused, as it was a loader tractor. Tires were pretty good and it did have a 3 point.
In my opinion, a narrow front is at least 1200USD less then a comparable wide front (I don't like narrow fronts). If you pay attention to other JDs of the same era, the narrow fronts always bring less then the wide fronts.
7500USD seems a little high, but then maybe that is what the market will support.
Personally, I'd rather spend 7500USD on a 4020 or 3020 diesel with powershift. You get a whole lot more tractor for your $$$s.
Brokenwrench
06-10-2004 04:15:37
$7500 seems to be about the average asking price for them.If it is running and shifting well,has all of it's side shields,complete 3 pt with top link,and tires are good,then it is within line. if it is missing side shields,or top link,then I would try to get the seller to adjust the price accordingly.Hoods,side panels,or other sheet metal are just about non existant,and the correct top links are hard to come by.
