Denjoe, you really need to get it lined back up so both plugs spark as those corresponding cylinders are at TDC ON compression.. ~That 420 has a � speed distributor so it is easy to get it to fire only one cylinder then not line up with the next one as the spark rotor only travels 1/4 turn between # 1 cylinder firing & #2 cylinder firing.. ~Pull the little timing cover from the bell housing,, then remove the spark plugs,, then rotate the engine in the running direction [a hand crank works best but you can put it in high gear & roll the tractor to do it also] until the front cylinder just starts to make compression,, then look in the timing window & continue rolling the engine until the DC mark lines up in the center of the timing hole.. At that time the distributor rotor should be pointing at the front cap tower contact [inside the cap] & the distributor points should just be starting to open [look closely to make sure they are OPENING & NOT CLOSING].. Then roll the engine � turn more in the running direction [either put a mark on the front engine pulley or use a piece of wire in the #2 plug hole to feel for the piston to be at TDC].. At that time the spark rotor should line up with the other cap tower contact [inside the cap] & again the points should just be starting to OPEN.. ~Once you do the above & get it to fire on BOTH cylinders, you need to set the ign timing.. To do that,, bring the engine back to DC [compression] on #1 cylinder,, then turn the ign switch on,, then rotate the distributor body in the running direction a ways,, then rotate the distributor in the non turning direction until you see a spark on the #1 spark plug [plug removed & laying on the engine block].. Any questions on the above just post back or E-Mail.. [email protected]
