4010 sold at farm auction last night FYI
KS in OK
06-09-2004 14:43:12
My dad went to a farm auction last night where there was a 4010 with JD loader, average to fair tin, less than 100 hrs on complete OH, 4 brand new tires, dont know the year of it but it brought $10,000. Just a little FYI from northeast Oklahoma. KS
Jim Snow
06-11-2004 20:30:20
 Re: 4010 sold at farm auction last night FYI in reply to KS in OK, 06-09-2004 14:43:12
Where are you located in SE Kansas. Snow.
G-MAN
06-09-2004 16:00:15
That's quite a bit of money for a 4010, but when you consider $1000+ in new tires, a $4000 overhaul and so forth, that's pretty reasonable. Of course the loader helps, too.
Jack
06-10-2004 05:18:17
 Re: Re: 4010 sold at farm auction last night F in reply to G-MAN, 06-09-2004 16:00:15
Why is that alot of money? If it was overhauled it has the 4020 spec on the engine.They are basically the same tractor, are they not?
G-MAN
06-10-2004 07:45:33
 Re: Re: Re: 4010 sold at farm auction last night in reply to Jack, 06-10-2004 05:18:17
It almost certainly was overhauled with 4020 sleeves and pistons, but that does not make it a 4020. The 4020 had several areas that were improved over the 4010, it wasn't a simple rebadging of an old design. Get a parts book for each and start comparing numbers, and you'll see what I mean.
Rodney A. Johnson
06-10-2004 07:03:57
According to JD dealer sales person, a JD 4010 diesel is only 200 pounds more than my JD 3010 diesel. That makes it 6,200#. A JD 4020 diesel (according to owners manual) without power shift is a little over 8000#.
If after the overhaul of a 4010D, the pump is turned up to attain the 93hp, you still have to add lots of weight or all you will do is constantly spin out.
I believe JD got the extra weight in the 4020 by having heavier blocks, and I believe heavier rearend housings, but I do not know that for a fact.
Plus the hydraulic lines on the 3010/4010 are 3/8 ID and the 3020/4020 lines are 1/2 ID if I recall correctly.
So, in my opinion, unless you do just stationary PTO work and no loader work, a 4010D is not the same as a 4020D.
KS in OK
06-09-2004 14:44:48
Sorry, It was a diesel also.
