24 T flywheel shear bolt problem
Peter Lawlor
06-09-2004 06:42:59
Just after excellent knots are tied I hear a loud clunk and the flywheel shear bolt breaks. This happens quite regularly. I will try keeping the flywheel bolt looser the next time around, to see if this helps.
I have adequate rpm and not feeding it too heavy. Knives are sharp, aligned and bale chute is snug. Will check the star wheel adjustment and the needle brake. Any other ideas? Could this be a timing issue? Thanks to any help provided.
peter lawlor
06-10-2004 06:19:39
 Re: 24 T flywheel shear bolt problem in reply to Peter Lawlor, 06-09-2004 06:42:59
Thanks for all the quick responses! ALL greatly appreciated! After 3 hours I was able to get her timed and baling. It was slightly out of time and the brake had to be tightened. Both were necessary after I started to shorten or tighten the knotter, feeder and main drive chains..timing of feeder teeth was good to go. Dogs are at bay!
Rodney A Johnson
06-09-2004 08:02:15
There is one other possibility, and that is the friction clutch/brake used to hold the needles in their "home" position. When the clutch/brake pads get worn, the needles can slide forward just enough to activate the safety catch on the plunger arm.
All you may need to do is tighten the bolts to increase the spring tension and things may work again.
Otherwise, it is likely you had a chain too loose and it slipped a cog putting your baler out of time.
When you have the bolt shear again, check to see if your needles are all the way back tight...
ET
06-09-2004 11:54:11
 Re: Re: 24 T flywheel shear bolt problem in reply to Rodney A Johnson, 06-09-2004 08:02:15
You may have to replace the brake facings because a groove will wear in them where the brake disk runs and the pads contact each other but don't put any preasure on the brake disk. No mater how much you tighten the bolts it won't help. If the problem isn't the brake my vote is for streched timing chains that will need replacing not shortening.
T213R
06-09-2004 07:32:09
The plunger is hitting the plunger stop. The reason it's doing that is because the needles are not fully retracted out of the bale chamber (needle carrier is not returning to home position) and that shears the bolt when the punger conacts the stop! Check your manual for the method of adjusting the needle carrier so that it stays fully retracted when it's supposed to!
Bob
06-09-2004 07:22:16
It's almost certainly timing or needle brake related. Run through the timing procedure as outlined in the owner's manual, and check the needle brake for excessive wear and replace or tighten it per the manual.
stew
06-09-2004 07:09:59
sounds like timing related ,, the stop blocks are stopping the plunger because the needles are not out of the way. make sure your needle brake is snug enough so that the needles are not just falling back alittle and tripping the stop blocks
John T
06-09-2004 06:59:31
Peter, most of my baler time was on a 14T, but they are similar and its been a while. I would have the shear bolt tight instead of loose and I wonder about the timing of the needles being back down and out of the way when the plunger comes back from your description of the problem??? Why not have a friend manually rotate the flywheel very slow and you trip it and carefully observe the needle n plunger and other things and maybe you can see if somethign is out of time, like maybe when and where the needles are relative to the plunger???? You may be able to feel a tight spot or bump as you manually rotate the flywheel as shes tripped???
Sorry, its been too long since I owned one of them radscals to give you the answer youre looking for.
Good luck n God Bless
John T
