what is this part
Ken C.
06-08-2004 21:01:30
Govenor on G JD. On top of the oil pump drive gear, there is a short shaft that goes up in the gov. housing, it is held in by a forked flange with one bolt. It has a small hole through it and a curved slot in it. What does this do and what do you check to see if it's alright. My IT manual does not say anything about it. Any help is appreciated, Ken. It turns with the oil pump shaft.
Mike M
06-09-2004 10:36:00
 Re: what is this part in reply to Ken C., 06-08-2004 21:01:30
That short shaft should run off of the camshaft and be held in the cam follower bracket. It should have gear teeth that mesh with the camshaft teeth so it turns when the cam turns to drive the oil pump.
