How to get good gas flow on '56 JD 60
ben
06-08-2004 08:37:15
If you let the tractor sit for a day or so and then start it, it will run for about thirty five seconds until it shuts off. Then if you try to start it again it will only fire once. Does any body know were the clog might be and how to fix it. I just bought a new fuel line from the bowl to the carb so there shouldn't be any clogs there but I have a feeling something is blocking off fuel between the bowl and the tank. What would be a way to see if theres a clog without draining the 2 gallons of gas that is already in the tank. If the only way to clean it is to take it off please tell me what to do and how to clean it. If you think the clog is some where else or if there is something else wrong please write back. THANKS, BEN
Ken C.
06-08-2004 20:46:04
 Re: How to get good gas flow on '56 JD 60 in reply to ben, 06-08-2004 08:37:15
I took the oil pressure setiment bowl off and bought a new one from napa without the pressure diaphram. Get a short peice of copper tubing, about 1 inch long that will just fit down in the top of the fitting that goes in the tank, then braze a copper filter with a 100 mesh screen from a spray rig tip on the tubing, this will stick up in the tank about an inch from the bottom and filter the gas. you can also screw a filter in the outlet from the bowl. Some of the older ford cars have a filter that will screw in the housing and has a hose barb on the other end. This will stop gas flow problems.
Mike M
06-08-2004 12:04:06
If you have one of those automatic fuel shutoff bowls take it off and rebuild it and clean it. I have seen a lot of those have junk up in the passages as they are smaller than the older type bowls.Plus the new diaphrams will help prevent future gas in oil problems.
Lon
06-08-2004 11:11:20
Ben, let's start backwards. Remove the plug from the bottom of the carb bowl. Loosen the round knurled nut on top of the auto shut off. Push on the top of the nut to open the valve. Is there good fuel flow? If not, the problem is above.
Remove the screen from carb(it's under that fairly big nut on top of the carb, right by where the fuel line connects). Is it dirty? Clean it.
Unhook the fuel line from the carb. Push on the knurled nut. Is there good fuel flow?
Take off the sediment bulb. Check the screen that is up by the gasket. Push the knurled nut. Is there good flow? No? Look at the gasket on the stem of the auto shut-off. Is it swollen so much that gas can't get by? Replacement is $.80 at Deere. Or, crud could have built up in the square hole that the round shaft goes through.(The fuel flows down through the square corners!)
If you still don't have good flow, you might have something blocking the tank outlet. On my 70, the baffle in the tank had broken loose, and I had to flip it over so gas could get under it.
BTW, to drain the tank, loosen the fuel line from the carb, put a funnel and gas can under the opening, loosen the knurled nut, and wedge the nut down with a wrench, screwdriver, or whatever.
