730 Power Steering - where to start
bent
06-08-2004 07:59:52
I am waiting for the JD power steering manual but I have the nose and hood off. Any tips on the basics before taking the PS apart would be great. When the tractor is running, the steering will work but locks at different positions and I have to jerk the wheel to get it to move. I don't really want to continue this. I noticed there is alot of silicon and an absence of gaskets around the valve and worm housing. Thanks in advance.
Brent
Tyler in MO
06-08-2004 09:26:51
 Re: 730 Power Steering - where to start in reply to bent, 06-08-2004 07:59:52
First thing you need to do is take a punch or chisel and mark the housings. This will greatly aid you in reassembly. It sounds like you have some pretty worn parts....good luck. Post back with any and all questions. Tyler
Clooney
06-08-2004 09:26:41
Bent, if you cruise the archives either here or over on Rummy's you should be able to find plenty of reading on Deere P/S problems. Either look under �steering�, �power�, or �Clooney�.. The search function only responds to single words 3 letters or longer.
~While there are plenty of things that could be wrong with your P/S system my guess is it�s an internal wear problem like pins, or helix slot.
~With all that gasket sealer you might also have a cam spring improperly set to height.. [it�s in the manual]
~I won�t go into much detail hear as you really don�t want to disassemble that late system until you have the manual in hand as there a few settings that you need to check & record BEFORE you tear it down so wait on the manual..
~If you have any specific questions I will be happy to answer those for you..
[email protected]
