Greg, you really need to pull the brake arm off the tractor to set those rivets correctly.. ~What I use is a round rod [or flat ended bolt]placed in the vise that is just slightly smaller than the rivet head size.. ~Then place the rivets in the pad & through the brake arm.. ~Then balance the brake arm on the rivet head on that flat topped rod.. [it helps to have 2 people but 1 person can do it with practice]. ~Then use a 5/16� transfer punch to set the rivet open ends. That transfer punch will not only set the rivet but will also roll the open end so it rolls over on the end as it sets [looks like production].. ~Set all the rivets lightly until they are ALL in place, then go back over & set them all tight.. ~If you don�t want to remove the brake arm you could do it in place but risk putting dings in the pulley.. ~If you aren�t looking for production you can buy some little brass bolts & nuts,, then grind [or file] the bolt heads flat [to look like the rivet heads],, then use the brass nuts to screw the pad on.. It works good, & once painted can hardly be seen, & is real easy to do.. [email protected]
