oldiron 48, assuming the oil isn't diluted with gasoline [give it a sniff test] it sounds like you are blowing the oil out somewhere. Those high flow old Deere�s don�t run a lot of pressure but do run quite a bit of volume.. That means that even with an internal leak the oil pressure will hold pretty good at high RPM�s but drop off drastically at idle.. ~My guess [remember this is just a guess] is that you have a distorted oil filter can top or leaking filter head to filter can gasket due to the oil filter cover being over-tightened at one time [very common problem].. Pull the lower filter cover off then stand back & look at the stud, if it�s crooked there is a good chance you have problem at the top of the filter can area [not an easy job].. ~To be sure what you are working with you need to pull the crankcase cover then look at ALL the oil lines for cracks, or being loose, or worn through from contact with a rotating part. ~If nothing found there get yourself a 1 or 2 gallon garden sprayer, then mix up a mixture of engine oil & diesel fuel, then drain the engine oil, then use a piece of rubber hose to attach that garden sprayer to the oil pump outlet line.. Once all hooked up use that sprayer to pressurize the oil system & see where the oil sprays out of.. Some oil from all the bearings is normal as well as from the governor housing but anything from the top of the filter area or excess from any one place is a problem.. It shouldn�t be hard to find your problem.. ALSO --You might just have a piece of dirt caught in the oil pressure regulator valve allowing it to not control the pressure so look there also. ~Your problem isn�t a pump pressure adjustment as you have good pressure at higher RPM [it�s flow problem, actually excess flow somewhere problem].� Any questions on the above just post back or E-Mail [email protected]
