need help 52 g
joe
06-07-2004 20:12:13
the cluth side is rusted on the crank any info on how to brake thise loose i'm to the point where the pulley should just slide off
Gman
06-08-2004 19:21:27
 Re: need help 52 g in reply to joe , 06-07-2004 20:12:13
Joe have you removed all the clutch componets,the driver has to be pulled of with a puller and there is a disc behind it. Dis connect clutch lever linkage from clutch fork assembly,remove the four bolts that hold clutch fork assembly in place then pull clutch assembly from housing the the clutch pulley should slide right off use a little PB Blaster (peneatrating oil) hope this helps Gman
joe
06-08-2004 19:55:27
 Re: Re: need help 52 g in reply to Gman, 06-08-2004 19:21:27
got all that done how much heat from a tourch can you use i think theres a brass bushing.
