46 B starter that turns on the dash light!! Hmmm!
Dave
06-07-2004 18:11:18
On my B when I press the starter lever, the dash light lights up!! and that's it! no movement or noise from the starter. I have not had the time to check into the problem for I am baling hay. Any clues as to what is happening will be appreciated.
Dave
Clooney
06-08-2004 04:13:14
 Re: 46 B starter that turns on the dash light!! H in reply to Dave, 06-07-2004 18:11:18
Dave, are you sure you are using the starter switch & not the headlight switch to try to start that tractor? [sorry, I had to ask]..
~Usually when lights come on while trying to use the starter it means a short between wires.. [poor ground connections or poor cable connections usually cause the lights to go out].
~Poor grounds & poor cable connections usually mean the lights all go out while trying to crank with the starter & not come on..
~You could possibly have some shorted wires as mice like to eat the insulation off of those wires over the winter.. [look at the rear of the ammeter where the light switch wires connect]..
~If the headlights work, try turning those on while trying the starter�If the lights go out while trying to crank suspect poor cable connections or poor ground connections,, if the lights just dim then suspect a low or under charged battery,, if the lights don�t do anything but stay on then suspect a bad starter or starter switch..
~Post back or E-Mail when you get a little more info on what�s happening..
[email protected]
Bob Collins
06-07-2004 18:36:18
As a rule of thumb, when strange things like this happen with an electrical system, look at the grounds first. Bob
TERRY M EAST KANSAS
06-07-2004 19:47:06
 Re: Re: 46 B starter that turns on the dash light! in reply to Bob Collins, 06-07-2004 18:36:18
GAWD, YOU GOT DASH LIGHTS? never had that. but to get the starter going, check your cables. i run 2/0 welding cable to starter (good for 540A) and 1/0 ground cable. can get the ground at a good NAPA. your starter also has a contactor on top of it thats pretty cheap to replace and is usuually the cause of "nothing" happening. have to open the starter box to replace it and i think you have to drop the starter out too.
how does it turn on the dash lights? the grounds sounds real reasonable and might be some wires touching near the ignition key too.
