GP sensitive throttle
KS in OK
06-07-2004 16:36:33
My GP has a very sensitive throttle ( approx 1 inch from min to max) Could this be the throttle spring adjustment, governor probs, both or ????? I removed the carb and cleaned it, how do I polish the brass outside and keep it shiney? Thanks in advance, KS
ET
06-08-2004 07:20:52
 Re: GP sensitive throttle in reply to KS in OK, 06-07-2004 16:36:33
The slugs that screw into each end of the throttle spring can be screwed in or out to ajust spring pressure. There are three cotter key holes in the rod to ajust engine speed with also. Be sure the linkage is not binding and the rod between the governor and carburetor is a half a hole short of going into the governor arm (the one on the carb. has a ball joint) when the throttle is wide open.
Randy V (SD)
06-07-2004 22:30:27
Does you governer arm move freely in the housing? have had several JD's that get carbon or rust on the governer shaft and it makes them act funny
