Brake help needed
Rick
06-07-2004 15:48:43
I have an early Model M. The manual says to oil the thrust bearing when reassembling the brakes BUT it says nothing about the little ball bearings and cups. Should these take a little grease or something? Or should I assemble everything dry?
Loren NC
06-08-2004 03:37:05
 Re: Brake help needed in reply to Rick, 06-07-2004 15:48:43
I know nothing about the M specifically, but my opinion is that where brakes are concerned, everything should be dry (except, of course, what they told you to oil). The more oil or grease there is in the assembly, the more dirt and crud you will attract. Eventually some of that will get into your brake surfaces, a result you DON'T want.
