4010 Crankshaft Rear Oil Seal
Pete
06-07-2004 15:34:36
Has anyone installed the new rear oil seal on the crank for a 4010/4020. Instructions that came with the seal say to use a JDG 476 seal installation tool set. Anybody have any info on doing this?
CMB
06-07-2004 18:08:25
 Re: 4010 Crankshaft Rear Oil Seal in reply to Pete, 06-07-2004 15:34:36
The last time I did this I borrowed the proper tool from my local JD dealer. I think it would be VERY hard to do this correctly without the proper tools.
G-MAN
06-08-2004 07:34:55
 Re: Re: 4010 Crankshaft Rear Oil Seal in reply to CMB, 06-07-2004 18:08:25
Impossible is a more accurate description. At least if you want to have any chance of the seal actually working.
G-MAN
06-07-2004 15:46:46
I've installed three or four dozen rear seals in Deere engines - be it a 4010 or a 8410 it doesn't matter - same tool and same procedure. It's pretty gravy IF you have the tool. The tool consists of a "guide" that bolts to the crank flange and has a threaded shaft on it. The actual installer fits fairly tight on that shaft and is pulled down it using a nut and flatwasher on the shaft. The installer simultaneously installs the seal in the bore and the wear sleeve on the crank flange. Do NOT separate the two, and always use the proper installation tool. Once the installer bottoms on the guide - make sure it actually bottoms on the guide and not the allen-head screws that hold the guide to the flange - the seal and sleeve are installed to the proper depth. The outer surface of the seal and the seal retainer bore should be clean and dry. I usually use a little retaining-retaining compound or plastic gasket maker between the wear sleeve and flange, although it fits tight enough that it's probably not necessary. With the tool, it's about as easy as can be, and takes all of two or three minutes.
Bob
06-07-2004 15:42:39
With all the work involved to split the tractor to get to the seal, your best bet is to borrow the tool and get the seal installed true with the crankshaft, so it lasts a long time!
