G Fuel Consumption
Stan - Florida
06-07-2004 10:21:13
Back in April of 1994 I had an article published in Green Magazine about a guy who claimed that when he was growing up his dad had three "G" tractors. Their farm wasn't large enough to justify three of them, but when his dad was asked why he had three of them, he replied,
"See that G down there in the field? It's doing a lot of work. See that one coming up the lane for fuel? See that one going down the lane after being refuled? It takes three Gs to keep one running in the field all the time".
That was a tough article to write, as I had to run most of what the guy said through an "ox filter" to strain out the BS, but he did make for some entertaining listening.
Greg S
06-08-2004 09:22:14
 Re: G Fuel Consumption in reply to Stan - Florida, 06-07-2004 10:21:13
Stan - A general rule of thumb to get you in the ballpark for most engines, is that they use about 1/2 pound of gasoline per horsepower hour. For example, if you are using 38 horsepower for an hour, you could expect to use 38 x .5 = 19 pounds of gasoline per hour. At 6 pounds per gallon, that would be between 3 and 4 gallons per hour. If you are running the same engine at a lower HP output, the fuel consumption would decrease as well.
CMB
06-07-2004 13:05:44
The "G" I started farming with, used about 4 gal per hr, after I had it bored & installed aluminum pistons. This was pulling 3/14s in 3rd gear in heavy Iowa "Clarion Webster" silt loam. If you went to the field before 8AM, you needed to take a 5gal can of gas with you & "stash" it in a nearby fence row, that way, when you stopped a few minutes for lunch,at 10:00 or so, you could add the extra fuel so you'd have enough till noon. Bear in mind, this tank only held 17 gals, & gas was only 14 or 15 cents per gallon back then, so we didn't really worry too much about fuel costs, especially since the "G" got so much work done. Thinking about that, people asked me, when I started in'59, just why I had such a "huge" tractor on only 140 acres. My answer was that I'd be farming more pretty soon (and I was).
Stan - Florida
06-07-2004 17:17:52
 Re: Re: G Fuel Consumption in reply to CMB, 06-07-2004 13:05:44
CMB,
I can relate to the 140 acre comment. Dad farmed 215 acres on three different farms in Hamilton County, Indiana. We raised 400+ hogs a year, so we did a lot besides raising crops.
Glad to hear you got bigger, and hope you're still hanging in there!
Stan Huff
Melbourne, FL
Brokenwrench
06-07-2004 12:34:36
40 years ago I plowed with a 52 G for my father.It was pulling 3-16's in bottom ground.I filled up and started around 8 in the morning and ran out of gas at the farthest end of the field right before lunch.After the walk back to the shed and then back to the tractor carring 5 gallons of gas,I learned to stop about every 3 hours and fill up when doing heavy work.Pulling the baler and a wagon it would go all day with about 4 gallons left to spare.I sure wouldn't want to feed a G plowing all day now with $2/gallon gas.
Stan - Florida
06-07-2004 17:13:57
 Re: Re: G Fuel Consumption in reply to Brokenwrench, 06-07-2004 12:34:36
Brokenwrench,
It's good to get answers back from someone who's "been there, done that".
Thanks,
Stan
G-MAN
06-07-2004 10:28:04
Yes, "G"s have a reputation for being fuel hogs, and some of it is probably deserved. However, I believe J.R. Hobbs pointed out that in those days, guys usually based their fuel-consumption opinions on how many tanks you'd burn in a day, not how much work you did in a day. Put in that context, of actual work accomplished, the fuel consumption of a "G" looks a little more reasonable.
Stan - Florida
06-07-2004 10:36:18
 Re: Re: G Fuel Consumption in reply to G-MAN, 06-07-2004 10:28:04
G-MAN,
No argument about the work done, for sure. As I mentioned, I had a hard time swallowing that tale, but it made a good story.
Only "G" I ever ran much was when I worked for a guy near Altona, Illinois in 1957. It was a fairly late model "G" and, compared to the '49 "A" I was used to, this was a step up.
Stan
