Baker Multi Valve Troubles
DAveH 50
06-07-2004 09:26:37
If there's an expert or two out there on Baker Multi Valves I could use some help. I put one on my 50 last fall and never tried to use it until yesterday. It was previously on another 50 that I had and it worked fine. It sat in a box on the shelf for about two years before I installed it on this 50. I only have hydraulic pressure in the top port and absolutely nothing in the lower port. Any ideas what might be the problem. I haven't taken it apart yet to have a look on the inside. I just ordered some more Power Trol gaskets and will wait until they are here so that I can at least still use the rock shaft in the meanwhile.
Thanks, Dave
CMB
06-07-2004 12:48:26
 Re: Baker Multi Valve Troubles in reply to DAveH 50, 06-07-2004 09:26:37
It's been a long time since I've worked with a "Multi-Valve", but as I remember it, there is a small pipe plug above & at about a 45 degree angle, to the hyd outlets. This plug provides access to an allen head set screw,down inside the valve, which is removed to allow oil to bypass & achieve one way hydraulics. If your valve doesn't have this screw, you'll have power on only the other side. Installing a screw here should provide two way power. If this doesn't help I'd have NO idea what the problem might be.
DaveH 50
06-07-2004 20:52:16
 Re: Re: Baker Multi Valve Troubles in reply to CMB, 06-07-2004 12:48:26
Thanks for the info. Unfortunately the screw was in there. I went ahead and took the Power Trol and Baker Valve off to find the problem. I should have mentioned that the lever moved further one way than the other. There was a BB in with the plunger inside of the Baker valve which would catch and not let it travel all the way! How did the BB get there? I have 4 boys who are always out shooting sparrows, spiders, wasps, and probably a few other things that they shouldn't. One of their BB's got in some part of the hydraulic system while the parts were off of the tractor and wound up in the Baker valve. Oh well I guess it could have been worse!
Dave
CMB
06-08-2004 04:35:17
 Re: Re: Re: Baker Multi Valve Troubles in reply to DaveH 50, 06-07-2004 20:52:16
Glad you found the source of your problem. Isn't it amazing the "wierd" things that seem to happen? Guess "Murphy's Law" is still in force!!!!!
