3020 Power Steering Leak
Greg C
06-07-2004 07:51:50
I have a 64 3020D powershift that has developed a hydraulic leak, coming from the steering column. I'm not as familiar with Deeres (this is my first one) but I think I remember hearing something about the steering being all hydraulic. Any help would be greatly appreciated. Greg
G-MAN
06-07-2004 10:19:38
 Re: 3020 Power Steering Leak in reply to Greg C, 06-07-2004 07:51:50
Yes, the steering is fully-hydrostatic on the New Generation and newer Deeres, with no mechanical connection between the steering wheel and front wheels. Where is the leak located? It could be as simple as replacing an o-ring on a fitting or as complicated as removing the entire valve for resealing and a rebuild. The latter is definitely not a shadetree job, as there are some very precise clearances to set in the valve if you want the steering to work correctly.
Greg C
06-07-2004 17:47:51
 Re: Re: 3020 Power Steering Leak in reply to G-MAN, 06-07-2004 10:19:38
The leak is coming from in between the steering wheel and the steering column.
