JD 60 PTO Horsepower
Bob Kiser
06-07-2004 06:58:59
I recently purchased a mint condition JD 60....I'm really happy with the tractor....I want to use it to run my Hesston PT 10 Swather..... .but want to be sure I don't over tax it..... I have the original operators manual, which refers to two types of HP ratings....draw bar and belt....there is no reference for PTO hp.... ? can someone illuminate me on this topic....?
Clooney
06-07-2004 09:37:42
 Re: JD 60 PTO Horsepower in reply to Bob Kiser, 06-07-2004 06:58:59
Bob, Deere John gave you the Nebraska testing procedures & the why's.. Just a little more from me here..
~Early on most tractors didn�t all have PTO's so the horsepower was taken on the drawbar [that is ACTUAL TRACTIVE horsepower not engine horsepower so wheel slippage & traction was figured in on that one.. The other horsepower was at the belt pulley as flat belt driven machinery was in wide use at that time.. The belt pulley was also a convenient place to get a usable ENGINE horsepower reading on most tractors..
~A little later on when PTO�s were becoming standard equipment some were included with the testing but on the early PTO�s some weren�t rated for full engine horsepower so it still wasn�t used as an engine power measurement�
~A little later yet [probably about the time of or just after your 60] belt pulley�s were becoming less used & some tractors didn�t even have them so the change over to using PTO output was used to measure engine horsepower & the belt pulley power measurement was discontinued. Later tractor tests just used drawbar horsepower [actual pulling power] & PTO horsepower [engine power at the PTO]..
~On your 60 the PTO horsepower would be slightly less than belt horsepower. It should be given somewhere probably in the operators manual. The good news is your 60 PTO is rated at full engine power so if your engine will pull it, it shouldn�t hurt the PTO assembly.. I don�t have any of my data handy where I�m at now or I would look the PTO horsepower up for you..
[email protected]
John T
06-07-2004 09:03:48
Bob, you already got an excellent very imformative post from Deere John, so I will just add a few engineering type comments. The various HP ratings measured at different locations on the tractor stems from sound conservation of energy principles. You cant create or destroy energy, only change its form, and heat losses caused by gear use and its friction uses up some of the HP the crankshaft delivers. Thats why the most HP is available on the belt pulley, its right there on the cranks end with no gears to go through,,,,, ,then the PTO drive gear system (not real big gears) uses up some energy which is why theres less HP available on it,,,,, and then finally, the big heavy drive gears use up more, which is why the least HP is available on the drawbar.
Good fun topic, God Bless Yall
John T
Deere John 2004
06-07-2004 08:16:52
This all goes back to the dear old "Nebraska Tractor Test". Although their HP rates were not always used by manufactures for published HP ratings, they tended to be accepted as "Standard". Until 1959, NTTs tested and published two types HP ratings, Belt HP & Drawbar HP. In 1959, the University of Nebraska decided that, since most farm machinery was PTO driven rather than stationary-belt driven equipment, they would discontinue the Belt HP tests and start testing PTO HP. They made no provisions to convert previously test belt HP to PTO HP, nor did they retest old tractors. The farm equipment industry followed suit.
Sometimes, you will see a Belt/PTO HP rating, as if the two were the same. Especially on a John Deere, they aren't because the belt pulley is on the crankshaft, and the PTO is geared (gears use HP). At the time, the general wisdom said that John Deere would come out worse in the 'new' PTO HP tests because JD's PTO used corner gears, and corner gears use more HP than straight gears. Other tractors used corner gears for their belt pulley and straight gears for their PTOs. (This is one of the reasons given for the end of JD's two cylinder engines.)
All this, of course, is much more than you wanted to know. The only reliable PTO HP ratings I know of for pre-1959 John Deeres is from PTO driven dynamometers manuals, if you can find someone that has listings that old. From memory, of about 1969, the John Deere "G" was rated at 36 belt HP, 32 PTO HP and 28 drawbar HP. If that conversion rate holds, the �60� should have a maximum PTO HP of about 34.3 HP. Hope this helps, Jon.
steveormary
06-07-2004 10:01:05
 Re: Re: JD 60 PTO Horsepower in reply to Deere John 2004, 06-07-2004 08:16:52
Bob Kiser;
JD 60 gasoline tested 40.24 PTO hp and 35.18 DB hp. Hope this helps.
