'56 JD 60 Won't run for longer than 30 seconds
Ben
06-06-2004 20:05:40
The old tractor runs smoothly for about 25 seconds before it starts to sputtter and fire on one cylinder even though I have spark to both. After all the sputtering it want's to die and theres know way of keeping it running. Another guestion is how many turns open should the two idle adjustment screws be set at. If anybody has an answere or even an idea of whats wrong please write back.
Ben.So.Tex
06-07-2004 09:58:11
 Re: '56 JD 60 Won't run for longer than 30 seconds in reply to Ben, 06-06-2004 20:05:40
My 60 was doing the same thing a few weeks ago,and I tought it was a fuel/carb problem. turn out to be a bad condensor, found this out after I change carbs from one of my other 60.... and then gave it a tune up new points,plugs,,,,But I did not change out the condensor.I tought it was good.. tractor still did the same thing,,Put in the new condensor and it runs fine now..Good Luck Ben..... ....
Dan
06-07-2004 07:43:08
Do you have the oil pressure operated fuel shutoff? If so perhaps it is manfunctioning. As other post mentioned could be something in fuel tank partially blocking fuel to sediment bowl. Or screen in sediment bowl blocked with dirt.
Ben
06-07-2004 09:04:37
 Re: Re: '56 JD 60 Won't run for longer than 30 sec in reply to Dan, 06-07-2004 07:43:08
It does have the automatic fuel shut off but it isn't malfunctuating. It ran a little longer with the oil bath pan off but after a little while of running I don't think it was getting as much fuel as it should be. OH and another thing is that when you try to give it more gas by opening the throttle it want's to die automaticly. If any has any information on how to get running long enough to drive it out of my barn and give it more gaas without it shutting off I would appriciate it. Thanks, BEN
Ty
06-07-2004 04:37:59
How's the fuel flow from the tank to the carb. Sounds like it dribbles full, you run it, and it can't refill it self fast enough.
