'65 3020 gas powershift...dog on power/hog on fuel
Shawn
06-06-2004 19:14:17
It seems to run fine at idle, but seems kinda slow on acceleration and blows abit of black smoke when you bring back to slow idle from a fast idle.carb ajustment? maybe timing issue? Any ideas would be appreciated...
Thanks...
Robert Barcus
06-13-2004 18:58:47
 Re: '65 3020 gas powershift...dog on power/hog on in reply to Shawn, 06-06-2004 19:14:17
Since I posted, I recieved an owner's manual. I checked the oil bath and the bowl was filled to overflowing with milky oil. It ran out all over. Seems to run some better now that there is the proper amount of oil. I also checked and the distributor cap is almost worn out. The contacts are just about gone. Will replace it and the rotor. That should make even more of a difference.
Robert
Robert Barcus
06-11-2004 03:08:00
Shawn, did you ever get your 3020 running better? I have a '64 that I just bought, and it looks like a diesel with all the black smoke. I have only had it for 2 days, so I have a lot of learning to do.
Robert
Shawn
06-12-2004 19:26:23
 Re: Re: '65 3020 gas powershift...dog on power/hog in reply to Robert Barcus, 06-11-2004 03:08:00
Robert, Yes i did get it running somewhat better.there was alot of small things i had to change but it seems to be holding it's own as far a power is concerned now but not sure about the fuel economy yet as i haven't done alot od work with it since i tuned it up.first off i replace the coil on it.Someone had put a 12 volt coil on it it.service manual calls for a 6 voltand the had it wired up to the distributor backwards.Timing was way off.book calls for 20 degrees before TDC @ 2200 RPM they had it set at 25 at an idle so maybe that might be something to check into first of all.It had Champion plugs in it. I've never had much luck with Champion plugs so ordered some AC plugs but can't tell ya the # off hand.some carb ajustments and it seemed to be some better..
Hope this helps
Shawn
Mike M
06-07-2004 10:02:58
Do you have one of those aluminum carbs.?
buickanddeere
06-06-2004 21:43:28
There was a run on this topic of 3020/4020 gas fuel hogs a while back. While no 720/730 diesel they can still be respectable. Crushed airfilter lids, plugged air intake pipework, choke plates still choking even through the linkage looks to the "open", too high float, levels to name a few. A pertronics ignition modual, 10 thou extra plug gap and matching pertronics coil never hurt. The manifold heat valve should be switched to heat and coolant run at 195F.
gene
06-06-2004 19:21:30
i am not for sure but does the 65 have a oil bath aircleaner on it?
i read a article about how the airtake on the aircleaners can an sometimes get plugged up an that would cause the problems that you are describing.
hope this helps just my 2 cents worth johndeeregene
Shawn
06-06-2004 19:25:36
 Re: Re: '65 3020 gas powershift...dog on power/hog in reply to gene, 06-06-2004 19:21:30
no this one has the dry filter element and it was replaced less than 100 hrs ago
Bob
06-06-2004 21:53:25
 Re: Re: Re: '65 3020 gas powershift...dog on power in reply to Shawn, 06-06-2004 19:25:36
Check your ignition timing, and check to see that the centrifugal advance in the distributor is working properly.
