'R' won't fire update
Swede
06-06-2004 18:26:57
Thanks to everyone for the suggestions on getting this green beast going. I've done everything suggested (bled lines, checked injectors for being plugged and made sure injector pump rack is moving full stroke. Still no pops. I just got the suggestion to check the crossover pump pressure. How much should it be? Does anyone think old fuel could be the problem? I'll get some fresh in it and find that out I guess. Thanks again for now....Swede
Gord
06-08-2004 06:03:28
 Re: 'R' won't fire update in reply to Swede, 06-06-2004 18:26:57
Hi Swede, The fuel pressure has to be six pounds or more that the crossover pump puts out. Gord
Tony
06-08-2004 05:05:56
By any chance have you checked the tappets and the decompression movement? That should be .090 when the lever is pulled back. If it is not releasing enough it will not get compression. Another dumb guestion, how about the air cleaner being full of dirt?
Randy V
06-07-2004 22:48:28
Swede,
Was this tractor sitting a while? I recently restored a 1937 cat D7 that had been sitting a while and had a similar problem. basically what it boils down to is that you don't have enough compression to fire the fuel. Either your cylinders are scored or rusted so that your are not gettiing a good seal or your losing compression by the valves. at any rate, if it is smoking white, you are close. try pulling it to start it or try ether. You may get lucky and get it to fire if you get those cylinders warmed up and the best way to do that is to turn the engine over as fast as possible under compression. I know that When it's cold I have to roll my R over for a while before the cylinders get warmed up enough to fire the fuel. on a day about 32 degrees out i have let it roll under compression for up to 5 minutes to get it to fire. good luck!
Walt
06-06-2004 19:37:01
This might be a wild stab in the dark, Your tractor fuel tank might have a shut off valve located where the fuel line is attached,It may be closed or plugged with sediment, The valve is barely visable after years of diesel and dust get mixed up.
Swede
06-07-2004 15:44:10
 Re: Re: 'R' won't fire update in reply to Walt, 06-06-2004 19:37:01
Thanks Walt. Fuel is getting to the injectors because I took them out and turned them out and cranked it over and watched the fuel squirtin' out. When I crank it over and move the throttle back and forth it will send out white smoke when the throttle is ahead of the shut-off position. It's all very puzzling to me.
