Edward, I doubt you have done any permanent damage, other than maybe you cleaned out some sludge, and she may develop some leaks now the sludge was helping to seal before. I doubt you damaged any bearings, but it may be possible depending on how diluted the oil actually became and for how long etc. I would drain the oil, repair the cause of gas in the oil (see below) and install new oil n filter n keep a close eye on it and your oil pressure for a while if it were mine. AS far as a lot of gas getting into the oil when the tractor was setting, even if your auto shut off sediment bowl feature failed, the carbs float/needle valve n seat would have to also have failed (maybe has dirt or gumemd up), or possibly the float leaks and sinks, cuz otherwise, it should shut the gas off when the float rises and gas reaches the the correct bowl level, NOT lettign it overflow n get into the engine. Where the oil lines tee into that auto shut off assembly, if removed, there SHOULD BE NO GAS there (only oil) and if so, its cuz the rubber diaphrams in those shut off pancakes have developed a leak lettign gas in. Its supposed to work by the oil pressutre present exerting force on the rubber diaphrams and opening the lil vertical gas shut off plunger. Then in the absence of oil pressure, the plunger rises n shuts off gas flow into the sediment bowl. You can buy the repair parts if your assembly is leaking at Mother Deere. If the sediment bowl is removed or you can see inside it, see if the lil vertical shut off plunger rises and stops gas from flowing into the sediment bowl ???? See if when you unscrew the top lil knurled nut and push down if the shut off plunger goes up n down freely??? Its another possibility the rubber diaphrams are okay (gas not getting into oil lines) but the shut off plunger or its o ring/washer is bad and dont shut the gas off PLUS your carbs float, needle n seat are not working to shut gas off at the correct bowl level..... .... When I rebuild a shut off assembly, I also replace the shut off plunger o ring/washer and clean n smooth where it seals. Change oil n filter,,,,, ,,, check the shut off assembly for leaky diaphrams,,,,, ,,,,check its shut off plunger for working free and sealing,,,,, (bad washer or gummed up surfaces etc),,,,, , make sure the carbs float n needle n seat are working,,,,, ,,,,make sure the floats not a leaker and sinking to the bowls bottom. Good Luck n God Bless you and all on the board. John T
