B Carb Problem?
Bob (So ME)
06-05-2004 19:13:50
Hoping for ideas on what to check out. Parked my 50 B 3 years ago in barn. It had a very bad fuel filtering system and ran like starving for gas. Last week I replaced the fuel sediment system and put fresh fuel in. I cranked 6-7 times and checked plugs and they were gas soaked. Cranked with plugs out and gas spewed out plug hole. Before I tear into something I shouldn't, need advice. Was thinking dirt could be in carb letting gas run wild? Any ideas? Thanks. Bob (So ME)
Bob (So ME)
06-06-2004 17:24:00
 Re: B Carb Problem? in reply to Bob (So ME), 06-05-2004 19:13:50
Hey Guys, you came through with a totally professional and common sense approach. I will move on the simple things first and work my way into it until it's right. Thanks for the road map to follow. I'll be in touch if the unexpected jumps out. Thanks so much. Bob (So ME)
John F in MD
06-05-2004 19:55:36
Your needle valve's stuck open. It probably just gummed up, or the float may have a hole in it. If it didn't run well before I'd take it off and give it an overhaul.
