Is it a 1010 or 2010?
Rich
06-05-2004 19:11:23
No serial number plate on a 1010 (industrial I think) I just bought. The engine number T 15277 is different from the trans housing number T 19169. What does that mean, and how do I tell if it is a 1010 or 2010? Thanks.
T213R
06-06-2004 16:02:50
 Re: Is it a 1010 or 2010? in reply to Rich, 06-05-2004 19:11:23
Tell me about the transmission. How does it shift gears and how many gears does it have? You will find that a 1010 has FIVE speeds and the 2010 has an 8f/3r transmission. The earliest 1010 tractors had a dash mounted shifter that didn't work out too well. Later 1010s had the same style and location shifter gate as did the 430 tractor. The 2010 always had a shifter that looked just like the syncrorange tranmission found in the 3010/4010.
Rich
06-07-2004 07:45:54
 Re: Re: Is it a 1010 or 2010? in reply to T213R, 06-06-2004 16:02:50
Thanks. Shifter is down on the footplate and is 4/1 so I think it is a late 1010. Steering also goes through the gas tank. Thakns again for the help!
Tony Miller
06-06-2004 06:09:29
Does the steering shaft go through the gas tank? If so it's a 1010. Seems to me the steering on the 2010 has a link that runs along side the engine.
