3020 Brake locked up
Ken
06-05-2004 15:22:54
My left brake locked up today. I played around with forward and reverse and it finally came loose. It has never happened before. Is something worn out? It is a powershift.
DON
06-06-2004 08:53:45
 Re: 3020 Brake locked up in reply to Ken, 06-05-2004 15:22:54
LOOK AT THE RUBBER BOOTS ON THE BRAKE VALVE. THEY ARE PROBABLY CRACKED, ESPECIALLY THE ONE THAT LOCKED UP . INSIDE THERE IS A PISTON THAT SLIDES THRU AN O-RING. THIS PISTON WILL RUST AND CAUSE THE BRAKE TO STAY ON BECAUSE IT DIDNT RETURN TO NEUTRAL. BOOT KITS ARE AVAILABLE FROM DEERE AS WELL AS O-RING KIT. REMOVE BRAKE VALVE ASSY AMD CLAMP IT IN A VISE TO HOLD IT. NOT A BAD JOB TO DO. NOT NECESSARY TO DISAMBLE THE ENTIRE VALVE TO FIX THIS. I HAVE PUT A JACK UNDER THE VALVE AN REBUILT THEM ON THE TRACTOR. DON
Ken
06-06-2004 12:41:41
 Re: Re: 3020 Brake locked up in reply to DON, 06-06-2004 08:53:45
Thanks Don I'll try that first.
Brokenwrench
06-05-2004 16:05:05
If it wasn't the master cylinder sticking,I would guess a piece of brake lining or other debris worked its way into the planetary.Kinda hard to diagnose from a keyboard,but maybe pull the axle off and check the brake and planetary.The last thing you need is brake grindings going through the powershift.
mike francis
06-06-2004 15:56:28
 Re: Re: 3020 Brake locked up in reply to Brokenwrench, 06-05-2004 16:05:05
If ti is your brake valve sticking , take off the line to that side that should release the pressure to brake , always check things out before you jump in and tare up more than you need to.
mike francis
06-06-2004 15:56:21
