6030 front wheel assist
dennie
06-05-2004 03:34:43
we have a 6030 want to add assist we saw a 4010 with levy assist wondering if there is a way to add to 6030
farmerboybill
06-05-2004 20:26:44
 Re: 6030 front wheel assist in reply to dennie, 06-05-2004 03:34:43
Put down the wrench and back slowly away from the tractor.
Based on what I have heard anyone who has ever been anywhere near a Deere tractor with FWA older than the 50 series, you'd be wasting your time and effort. Those hydrostatic FWAs were nothing but a nightmare. If you really want a FWA tractor, just step into a 50 series or newer. It's well worth the 35 grand you plop down.
Brokenwrench
06-05-2004 04:55:08
I'm not saying it can't be done,but with all the expence of machining parts, adapting,and rewiring you can probably buy a 4850 MFWD,or switch up to 30L-32 radial duals.You steer with cylinders,the fWA axle steers with tie rods,the mounting saddle that bolts to the frame is smaller/lighter,the axle tubes are smaller,the spindles,and hubs are lighter than the 6030.All of the assist axle parts would have to be bushed up to fit your axle pivot,and then adapted to your steering setup.You would need the hydraulic manifold,hoses,fittings,and wiring harness,and assist axle off a salvage 4430/40 tractor.You will have to fabricate switch mounts on the shifter,clutch and dash,and replumb the hydraulic system,and upgrading to a higher capacity hydr. pump.Figure on resealing the hydraulic motors on the wheels of the assist axle as they are prone to leaks.You are also limited to a 13.6x24 tire,without widening the wheels,and really with a larger tire you will over power the motors. Just some things to think about.
