Does any one sell bulk felt for seals ?
Marty Z
06-04-2004 22:57:12
Can't seem to find enough felt for the seals on my GP final drive. Does any one have a source for bulk sheets of felt so I can make some seals my self ?
Thanks
Marty Z
ET
06-07-2004 04:42:30
 Re: Does any one sell bulk felt for seals ? in reply to Marty Z, 06-04-2004 22:57:12
You can use gasket material to make shims to get a little bit of crush on the old felt seal if they are not destroyed from use. Shim against the non rotating side of the felt. I used this method in my GP axel seals.
Earl S
06-06-2004 14:43:37
Marty, As I looked through my brg.,seal cataloge this aft I noticed they offered felt seals .Give me a dimension,OD,ID width I will look to see if there is a listing.You can email ok. Earl In Illinois
Duane Larson
06-06-2004 08:13:33
Marty,
Depending on what felt seals you need, I just got some AC1107R rear axle felts for my GPWT from Greg Stephens at www.theoldtractorcompany.com I have made felt seals in the past using the material from McMaster-Carr and the biggest problem is producing a nice, sharp cut. Hole saws work about the best, but if the saw does not match the needed hole ....
Martin J Zielinski
06-05-2004 22:56:44
Thanks
Got the link and some ideas.
Marty Z
Mike M
06-05-2004 11:49:35
I have heard of people putting oil seals in those tractors. They measure the shaft get seal to fit it then make a spacer/bushing to get them to fit into the housing tight. I have never done this yet on a GP but have on a D brake shaft that had an oil seal that was a special size and couldn't get any more.
Earl S.
06-05-2004 09:05:20
McMasters-Carr www.mcmaster.com Phone-404-346-7000 They have sheets up to 1 in. thick
