1010 power steering
Tony Miller
06-04-2004 18:46:00
I purchased a 1010 with live PTO nearly two years ago primarily to pull a 6 ft finish mower. The tractor works very well for the task, but the lack of power steering was killing my arms. I recently retrofitted an aftermarket system consiting of a torque amplifier from Danfoss and a proportional flow divider from Prince. The installation looks almost factory, and is a very tight fit but works great. With the flow divider I have sacrificed a little speed at the 3 point, but the trade off is well worth it. Total cost in components is under $500, and the modifications would be easy to do now after being through it once. If anyone is looking to add power steering to a 1010, I'm willing to offer help if I can.
Loren NC
06-05-2004 04:27:03
 Re: 1010 power steering in reply to Tony Miller, 06-04-2004 18:46:00
I have a 1010 without power steering and have thought some about adding it. My concern was that I would lose too much power, since the tractor isn't over-powered anyway. Where did you find the components for yours? I presume not at J-D. I have a shoulder that is susceptible to bursitis and which would sure appreciate some relief!
Tony Miller
06-05-2004 06:22:08
 Re: Re: 1010 power steering in reply to Loren NC, 06-05-2004 04:27:03
Okay, in detail.
www.sauer-danfoss.com
Select Literature on the left
Expand the Steering category and Select Open/Closed Center Steering Units
Download the PDF and look for the TAD (Torque Amplifier Units) I used the TAD100 unit. I was able to locate a distributor through their website as well. When you order the unit, ask for the weldable spline stub that connects to the input of the unit.
You will also need a 7/8" diameter solid shaft coupling with a 3/16 keyway that is under 1.5" in diameter. McMaster-Carr or Reid Tool Supply should have these.
You will also need an RD550P proportional divider that you can order directly from Prince Hydraulics.
www.princehyd.com
Dissasemble the hood and side panels on the tractor. Remove the air filter. Loosen the rear spline connector in the steering shaft, and slide it all onto one side. Loosen the front spline connector clamp bolt as well. Remove the four bolts holding on the gas tank. Lift the rear of the tank and slide out the steering shaft. Remove the steering wheel. Remove the four bolts holding the steering cloumn in place. By tipping the column, you can slide the shaft with the U-joint out of the column without having to disassemble the throttle linkage. It may be helpful to remove the four screws holding the dash panel on.
Cut the splined stub shaft attached to the U-joint off almost flush with the U-joint (the one that connects to the steering shaft through the tank, not the one the steering wheel goes on). Leave enough (1/16") so you can find the center of the U-joint. Then you have to drill or bore a hole in the U-joint on center with the shaft that you can press the stub spline you get from Danfoss into. After you press in the spline, weld it in place. This shortens things as much as possible.
Now you can put the steering column shaft and U-joint back in place and the steering wheel back on, and bolt the column back in place temporarily. Put the TAD 100 unit in place, engage the spline, and hold it in alignment. It may be necessariy to remove the tachometer cable from the tachometer. Measure from the end of the output shaft of the TAD unit to the edge of the hole in the gas tank bracket, and write down the dimension. Remove the TAD unit and slide the steering shaft back through the gas tank and engage it with the steering gearbox. Measure from the gas tank bracket back the same dimension and mark the steering shaft so you can cut it off, but when you cut it, cut off an extra 1/16-1/8" for clearance.
The steering shaft is 7/8" diameter like the TAD output shaft. You may want to double check that everything fits so far before the next step. Slide the 7/8" shaft coupler half way onto the steering shaft, and weld it in place. You may have to sand some paint to get it to go on. Now you should be able to put everything back in place (steering shaft, steering column, and TAD unit) and layout the torque reaction bracket needed to mount the TAD unit. The assembly is a little difficult now. Remove the steering column bolts. Slide the steering shaft in from the rear of the tank and engage the steering gearbox. Put the TAD unit in place and slide the output shaft into the shaft coupling. Then slide the loose steering column in place, engaging the splines, and bolt it down. Now you need to take some measurments for a angle bracket to mount the TAD unit to the framework that holds the steering column and dash in place. I made one out of 10ga sheet metal that I bent into a angle. One leg of the angle bolts to the TAD unit according to it's mounting dimensions, and the other leg of the angle bolts to the same plate that the steering column bolts to. It works okay, but really needs a gusset welded in the center to be more rigid. A solid block that you could tap the edge of for the tractor mounting would be better, but take more machining.
After the bracket is made, you can put the steering shaft and column all back together. Remeber the last step is sliding the spline on the steering column U-joint into the TAD unit, and bolting the column down. It won't assemble any other way. You can now put your air clearner back on, but you will have to do a slight modification to the top edge with a ball been hammer to get it to clear the TAD unit. Just make a little indentation in the corner as needed. It does not show with the hood back on.
Whew! Now to the hydraulics.
The RD550P proportional divider can be screwed into the top of the pump with a 1/2" npt hydraulic nipple. From there you get two adjustable output flowrates. Conect the Touch-O-Matic pressure line to one, and run a hydraulic hose from the other to the pressure side of the TAD unit. From the Tank side of the TAD, I was able to run a line back to one of the drain plugs on the Touch-O-Matic housing (resevoir). I know some of my tratctor's fittings where not factory orginal, so you'll have to figure out exactly what fittings you'll need. You can adjust the proportion between the flowrates so that you get the best compromise in lift speed and steering speed. With more work, a larger pump could be added.
Now that I have your head spinning, don't worry about loss of power. The system requires 1015psi at about 2.6 GPM. That equates to less than 2 horsepower at worst. I'm surprised you say the 1010 is underpowered. I have no complaints for power on mine, but I have a fresh engine. It'll pull the 6ft finish mower in third gear through 8" tall grass, no problem.
Hope this helps!
