Head gasket leaking?
Hal
06-04-2004 17:39:01
I recently finished restoring my 37B which included complete overhaul of the engine and am noticing that sometimes when I crank the tractor I am getting a small amount of black spotting(sooty looking) on the hood and the only thing I can figure is after sitting for a few days my head gasket has a slight seep into the cylinder the oil looks to be OK, I retorqued the head the other day and cant see that that helped any Thanks for any suggestions Hal
Lonnie
06-05-2004 18:38:23
 Re: Head gasket leaking? in reply to Hal, 06-04-2004 17:39:01
I have an H that does the same thing. I think that it is just a little condensation that liquifies under compression on intial startup until the combustion chamber has time to heat up to dry the cylinder. I have a couple of hit and miss engines that have a milky mixture on the piston until it warms up. I wouldn't worry about it, just keep an eye on water level in radiator. Another check that I did w/ the H is to pull the spark plugs & w/ a small piece a paper towel attached to a wire insert it into the combustion chamber & swab it around to see if water was collecting in bottom of cylinder. Mine was dry. I really don't think you have a problem though.
At least you rebiult you engine. I hear of alot of people giving their equipment the KRYLON touch out of a can & claiming they restored it. How sad is that!
Hal
06-05-2004 21:13:31
 Re: Re: Head gasket leaking? in reply to Lonnie, 06-05-2004 18:38:23
I am also running a straight pipe I guess if I had a muffler with some baffles it might not ever make it out It seems to be more water based than oil based
Dean Van Peursem
06-04-2004 23:38:19
My first guess is that it may be nothing more than a some normal exhaust emissions. Remember, that since you just overhauled the engine that the rings probably haven't seated yet and will take some time. Especially if the cylinders were just honed and not re-bored.
If the head gasket were leaking, the symptoms would be white smoke coming out the exhaust pipe due to water getting into the combustion chamber, not oil.
It also may be running a bit too rich as well. I would make sure your carburetor is adjusted right and work the tractor a bit, to get the rings seated before I would get concerned.
