67'4020D Hydraulic pum shaft
ForrestKY
06-04-2004 06:31:53
I am replacing the fan belt on my 4020 and the splined shaft from the hydraulic pump to the coupler is not bolted down tight. I am assuming that it should be able to slide to prevent damage but since this is my first time I wanted to ask the experts. Thanks so much for all the help you guys deliver.
ForrestKY
06-06-2004 07:47:27
 Re: 67'4020D Hydraulic pum shaft in reply to ForrestKY, 06-04-2004 06:31:53
Thanks for the help. The coupler bolts are bottomed out so it looks like I will need to replace it. Thanks again.
Bob
06-04-2004 07:41:32
The splined coupling must be torqued down TIGHT on the pump shaft. If it has been run loose and worn, it will knock. Usually, the cast iron coupler wears worse than the hardened steel pump shaft if run loose.
Dan
06-04-2004 06:54:02
It should be tight on the pump shaft if that is what you are asking. The coupler on the engine end has some give and I suppose would be the first place to go if the pump locked up or something.
