Mark, I presume when you say "that the power trol is making lots of noise" you are talking about the governor mounted pump? ~If it is the pump you want to remove? I really can�t say for sure if that LP tank has to come off [or lifted up] to get the lines & pump loose.. I work on so very few LP tractors [there aren�t many LP tractors in my area up north here] that every time I work on one I have to address the differences as I get to them. I guess you will have to try to get the lines loose & pump off by removing or moving whatever gets in the way.. [maybe someone that is familiar with the 620 LP pump area will post in here & help].. You say.. Quote: �maybe a gear or bushing is bad making that rattle knocking noise. And is the 620 a good tractor. ( what I mean is it prone to break downs more than a 60.)� >>> _~If I had to guess at what is making your pump noisy I would say the idler gear, or the gear or shaft bushings are worn & loose [somewhat common on a well used tractor].. On the 620 being a good tractor, yes it is an excellent tractor & you will find it quite useful, the 620 has good gear ratios, good fuel economy, & if P/S & float ride seat equipped quit conformable.. As far as being better than a 6o in my estimation the 620 is much superior but that is just my opinion.. One thing: your tractor being an LP means the engine is probably in pretty good shape as LP fuel is much easier on the engine internals as it is a clean burning fuel with few harmful deposits left in the engine.. [email protected] ~
