Help! Timing an A distributor
MAD DUC
06-04-2004 03:54:18
Putting my 47 A back together and need to know how to set up the distibutor timing. Have the LH Impulse dot lined up with the indexing line on the gear cover. What next??
John T
06-04-2004 06:14:37
 Re: Help! Timing an A distributor in reply to MAD DUC, 06-04-2004 03:54:18
Good Morning DUC, Heres a simple 3 step procedure for how I would set up the initial start timing on a Distributor Ignition:
1) Once you have the ignition points gap on high cam set properly,,, and the Left piston is at TDC,,, install the Distributor (bolts in place but not too tight) into the Governor (rotating as needed so it fits into slot) so the rotor tip is pointing to where the distributor caps Left plug terminal is/would be located. NOTE: Having the point gap set first determines when they open as the distributor cam rotates to raise them, and that affects timing.
2) Next, retard (rotate distributor CW) the timing to max retard. If the flywheel to crank and cam to crank and governor to cam are all in time, at max retarted, the ignition points should be closed, but the distributor shafts cam close to where its gonna start to raise/open the points as its advanced.
3) Replace the distributor cap,,,,,install the left plug wire into the caps top (to left cylinder) terminal,,,,, have the plug and its wire attached but with the plug removed and its side against tractor frame ground so you can observe the plugs firing,,,,, ,,turn the ignition on and,,,,, ,,,,,very slowlyyyyy yyyyy advance the distributor timing (rotate CCW) just until the plug fires,,,,, ,,,(it will fire as the points break open) tighten the distributor down.
That sets up the timing for approximate start firing right near TDC, and then the run time advance is determined by the distributors mechanical advance mechanism. If you used a timing light, you could then observe when she fires relative to an increasing RPM, this procedure merely sets where shes starts at.
I hope this helps and answers your question. If not or any questions, you can e mail me at [email protected].
Good luck to ya n God Bless you and all on the board.
John T Nordhoff
Clooney
06-04-2004 04:34:00
MAD DUC, you didn't specify a distributor type [Delco {round body} or Wico {oblong body}]..
~In either case once you have the flywheel to case, or flywheel to flywheel cover dots lined up [L/H piston TDC] just install the distributor with the spark rotor pointing to the top [or number one] plug tower contact in the cap,, then rotate the distributor�s top all the way forward,, then install the L/H plug wire with a plug in the wire & laying on the engine block,, then turn the ignition switch on [the power wire to the dist must be hooked up],, then s-l-o-w-l-y turn the top of the distributor to the rear until you see a spark on that L/H plug,, then tighten the distributor down as it is timed..
~The above is the static way.. If you want to time it dynamically [fancy word for running] just � Use a flexible tape measure & measure the circumference of the flywheel [excluding the ring gear teeth],, then divide that measurement by 360 [that will give you inches per degree],, then multiply that number by the advanced degrees you want to run [usually 25� or 30�],, that will give you a number probably somewhere between 4� & 5 � [something like 4.3�or 4.7� or in that ball park],, then turn the flywheel so the L/H impulse mark is at the rear,, then measure up from the L/H impulse mark on the rim of the flywheel the amount you figured in the above & put a paint mark,, now hook up a timing light to the L/H spark plug & run that engine at fast idle [wide open],, then just point the timing light at the rear of the flywheel & adjust the distributor�s position until the paint mark you made lines up with the case cover mark.. AS EASY AS THAT..
Any questions on the above just post back or E-Mail..
[email protected]
MAD DUC
06-05-2004 08:32:26
 Re: Re: Help! Timing an A distributor in reply to Clooney, 06-04-2004 04:34:00
Dynamic it will be. Measured the flywheel,60.25 inches gives me 4.175(4 3/16) and 5.0. Will put two marks on it so I can see which setting, 25 or 30 degrees, gives best power. Thanks for the great tip.
MAD DUC
06-04-2004 19:07:33
Thank you Clooney and John T! When I took it apart last fall the rotor was pointing down and thought that I read/learned here that it was supposed to be up. Dist must have been 180 off. Also sorry did not mention it is a Delco with an electronic ignition. Hope she will be running by Sunday. $$pent all winter rebuilding and just about done!!!
John T
06-04-2004 22:23:32
 Re: Re: Re: Help! Timing an A distributor in reply to MAD DUC, 06-04-2004 19:07:33
You're most welcome, glad we were of some help. Yep, the rotor pointing upwards in line with the caps top plug tower to the left cylinder is the original setting for firing the left piston on its TDC. You may have had it 180 different before??? An elec ignition is similar in timing as we described, its just that instead of the points opening to fire the coil, a magnet on the distributors shaft (instead of the cams high lobe) passing by the pickup coil fires it instead. Therefore, as you advance the distributors timing CCW, when a magnet on the distributors shaft comes in line with the pickup coil (similar to points opening on cam), the left plug should fire.
Best wishes, John T
MAD DUC
06-05-2004 08:27:02
 Re: Re: Re: Re: Help! Timing an A distributor in reply to John T, 06-04-2004 22:23:32
Should of explained that one better. When the rotor was pointing to the top contact, that wire ran to the right side plug, bottom to the left plug(viewed from sitting in seat).So I figured the dist was installed 180 out. Thank you again, and yes you have been more than some help!
